Old 04-10-2009
sailingdog sailingdog is offline
If you're going to through-bolt the ports, I recommend that you chamfer/countersink the holes on both sides slightly, since that will help prevent stress cracks from forming at the holes.
Originally Posted by sww914 View Post
There's no question that he knows more about plastic than I ever will but I can't help but doubt his statement about never screwing down any plastic. I've seen so many kinds of adhesive in so many different applications fail. I've also seen about a gazillion racecars with plastic windows screwed in. A very different but also very harsh environment.
It is necessary AFAIK to drill the screw or bolt holes oversized and install grommets in the holes to insulate the plastic from any shock or concentrated pressure from the fasteners. I've used screws and bolts with shoulders to install plastic windows to prevent over tightening cracks in the plastic.
