Old 04-12-2009
sailingdog sailingdog is offline
Major differences between ski gear and marine gear are:
  • Retroreflective tape on the gear so that if you go overboard, there's a better chance you'll be spotted.
  • Inner cuffs seal tightly to the wrists to prevent water from going down the sleeve when reaching up to adjust something...
  • Usually not insulated, and requires you to layer beneath... yes, you can get pretty hot working on a sailboat.
  • Pockets often have drains in them so that water doesn't get trapped in the jacket pockets
  • Most have a hood, which a lot of skiing gear does not.
  • Collar is often higher than that of ski gear, and usually fleece lined so that it doesn't irritate the skin.
  • Marine gear is often better vented, since the average temps are higher.
