SailNet Community - View Single Post - Origo/CookMate gimbals
post #2 of Old 04-12-2009
sailingdog
Yes, the thumbscrews go through the hole in the right end (of your image as posted) of the big square plate. That puts the axis of rotation about where the pan's contents are...so that the pan's contents slosh the least. The further the pans are from the center of rotation, the bigger splash it makes...
IIRC, the sliding part is to allow you to lock the stove and prevent it from swinging.
You can see the setup in this image of the assembled stove and bracket:
photo courtesy of binnacle.com
sailingdog is offline
