Old 04-13-2009
DrB DrB is offline
DrB is on a distinguished road
I'll take a stab.........
"Heavy" most likely means the cloth weight, with heavy meaning
"offshore" or "capable" of handling much higher wind velocities. Most of the heavy weight cloths are in the 7 to 8 ounces/sq yard minimum. Light means a lighter weight cloth, typically for inshore or coastal conditions, anywheres from 4 to 7 ounces/sq. yard.
The numbers refer to the rank in order of relative size. A #1 typically refers to a headsail that has the max range of overlap for your boat, so it would be the largest. For some boats it is 180% of the fore triangle, some 160%, some 150%., a number to 2 would be smaller, maybe 140 to 120%, a #3 would be 90 to 110% ish, etc.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
