Originally Posted by Melrna
Thanks for the reply saildog.. The questions you asked I answered in my write-up except for the wire size to the batteries which are 0 AWG. So please read my write-up. You always get mad at people who don't ask a question intelligently for which I think I did well. So please do the same when answering.. RTFQ!
1.What state of charge are the batteries at???
I used 30 amps the first time and 90 amps the second time.
Did you start at fully charged batteries or somewhere lower than that... saying you used 30 amps and 90 amps doesn't mean jack, without knowing where you started from.
2.Batteries are Flooded wet cells
3.As to the battery bank I plan on next month upgrading the house bank to over 500 amps, why the big alternator.
Having said that I believe you did answer my question about how many amps the flooded wet cells will take. It seems the AV-5 is smart enough to only allow 60 amps to the batteries so as not to ruin them. If that is the case than all is normal. Why I bought the smart charger to begin with. I have never had experience with such a set-up.
At 60 Amps... it is still very likely to damage the batteries if you're doing it for any extreme period of time.
Are you replacing the existing 4Ds or going to use them with the new batteries. Also, how old are the existing 4Ds?
BTW, I was trying to help you and having an attitude really isn't a good idea.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
