SailNet Community - View Single Post - Chain Plate (Not)
Old 04-13-2009
riphonda riphonda is offline
Ornery Cuss
riphonda is on a distinguished road
Its actually well connected and adds effective stabilization
That forward lower stay was added to remedy the "mast pump" failure that the early sabres suffered from and consequently some even lost their rigs to the point that sabre immediately sought to fix the issue. The stay is bedded in a solid glass pad in the cabintop and works quite well- though it might not look like it is certainly attached solidly (no plywood to rot there just solid as a rock) Now the other chainplates, however, are prone to seeping water into the bulkheads which are usually questionable. I have the same boat and just had to replace the main bulkheads as there was nothing left of the wood after 33 years... only about an eighth of an inch of good wood left from 3/4" when new. Check out the rotten main bulkheads from the leaking chainplates, pretty gross:
1976 Sabre 28
"If at first you don't succeed, destroy all evidence that you tried...
