SailNet Community - View Single Post - CruisAir system freezing up on heat cycle
post #1 of Old 04-14-2009 Thread Starter
BigMoe's Avatar
Unhappy CruisAir system freezing up on heat cycle
I have a 2009 Beneteau with two CruisAir air conditioning/heating systems. My problem is they are freezing up in the heat cycle. The sea water temperature is around 55 degrees. I cleaned the intake strainer. Both units definitely have water flowing through them and out the through hull. They will not give me more than 60 degrees Fahrenheit. The salon unit is getting a thick layer of ice on the compressor unit. Air is flowing out of the vents at full speed. Help!
Thanks, Big Moe
BigMoe is offline
