SailNet Community - View Single Post - Frozen Prop
Thread: Frozen Prop
post #11 of Old 04-15-2009
lynger1
Lynger1
Hi just calm down
having had that problem with some other boats
just get small angle grinder with steel cutting blade grind/cut lengthwise with the shaft go just deep that you don't hit the shaft
do the same on other side and just grind/cut to the shaft try to avoid marking shaft
This Will fix it Will take you around 1/2 hour
Done
lynger1 is offline
