SailNet Community - View Single Post - Frozen Prop
Thread: Frozen Prop
post #16 of Old 04-15-2009
jonb
I had the same problem removing my prop in the winter.
I finally needed to use the combination of a suitable prop puller (I needed to modify it so that it didn't damage the prop hub), penetrating oil (PB Blaster in this case), and heat from a propane torch.
I had no luck with any subset of the above and was convinced that it was not coming off. With the above it came right off.
C&C 44
Kingston/Lake Ontario
jonb is offline
