SailNet Community - View Single Post - Cracked Exaust Manifold.
Old 04-15-2009
sailhog sailhog is offline
sailhog has a spectacular aura about sailhog has a spectacular aura about
The exhaust backpressure is supposed to be between 1.0 and 1.5 p.s.i. I'm not sure about hte water presure, but I'd think it wouldn't be that great. Try the J.B. Weld, along with replacing the hot section of your exhaust. You can pick up the black iron pipe for this at Home Depot for about $25. If the J.B. Weld doesn't work, you'll be buying a new exhaust manifold from Moyer for about $350. All the attendant parts, such as the exhaust flange and heat wrap, will run you about $450 with shipping.
