SailNet Community - View Single Post - Dry Ice, How Much?
Old 04-15-2009
huguley3's Avatar
huguley3 huguley3 is offline
huguley3 is on a distinguished road
I have been experimenting with both block,cubed and dry ice in my 5ish cubic foot icebox. The top is not insulated very well but the sides are. I have not had any trouble with stuff freezing unless it is right by the dry ice. Have not had any trouble with the CO2 produced either even with the boat closed up. One thing I will note is that you do not want to stick your head too far into the icebox or breath into it with the top off. The CO2 is pretty strong and I am sure you will note the same thing if you try it.
I found that 2 blocks of dry ice of around 9ish pounds would last a bit over 3 days. Each block is about a foot square and 3 inches thick. You can quickly chill a beer by putting it on the dry ice for about 45 minutes. If you forget it it will freeze solid.
I liked the dry ice better than block ice because my icebox drains into the bilge. I put a plug in the hole and just empty it in the morning to help hold some of the cold in. But spending $200 a month on dry ice has me looking at converting the icebox to a fridge. Dry ice is $1.29/pound where block ice is much cheaper.
I put the dry ice on some of those blue freezer packs that were pre frozen so if the dry ice all sublimates I still have some cooling in there. Once the dry ice is gone the temp starts to rise pretty quick without some mass to keep it cooler. Right now I am buying a couple of blocks of ice and an occasional block of dry ice. Blocks do last a LOT longer than cubes and stack more efficiently as well.
30' Islander Bahama
