SailNet Community - View Single Post - Balancing Engine Weight While Aligning
post #4 of Old 04-15-2009
SteveInMD
In theory you should be able to have both exact alignment and fairly even weight distribution. The weight distribution wont be exactly even since different corners of the engine weigh different amounts. I think you need to keep working on the adjustment. First get the coupler in the correct location with the mounts closest to the coupling, then align it with the mounts farthest away from the coupling.
SteveInMD is offline
