SailNet Community - View Single Post - AGC fuse ratings
post #5 of Old 04-15-2009
sailingdog
Brak—
If you think of a circuit as a tube and the electrons as marbles... the amperage is how many marbles pass a given point in a given amount of time... the voltage is how steeply tilted the tube is... 250 volts would be a tube that is at a 80˚ angle from horizontal and the marbles move pretty quickly... 12 VDC would be the same tube at a 20˚ angle from horizontal... the marbles still move, but not as quickly...
If you cut a section out of the tube... that would be a blown fuse. The higher the voltage, the more likely the marbles are to jump the gap. At 20˚ from horizontal a small gap would probably drop any marbles trying to cross. At 80˚ the gap probably has to be a bit larger for the marbles not to jump it.
sailingdog is offline
