Spot on "but". Mainly "but" the POE cable may require a 48 volt power supply (!) which is usually a wall wart that needs 110/120VAC. The actual device may only require 12VDC or less, so it may be possible to replace the POE power wart with a simple nominal 12VDC (ships power) connection instead. Key words "may be" and you'd want to check that out.
