Old 04-16-2009
sailingdog sailingdog is offline
I wouldn't ground it directly to the battery terminal, but to the 12 VDC system negative ground post or bus bar instead. Also, the distance determines what gauge wire to run. Look at the Autopilot's maximum amperage draw and base your wire size on that.
