SailNet Community - View Single Post - Manual Bilge Pump
post #6 of Old 04-17-2009
sailingdog
Backcreek—
I'd recommend you put that either in your signature or your user title... since that makes it readily available...
As for the pump... most diaphragm pumps are fairly easy to rebuild... if a rebuild kit is available..and that is usually far less expensive than replacing it. Could the pump be connected to the shower sump??
sailingdog is offline
