SailNet Community - View Single Post - Removing headline?
post #2 of Old 06-10-2001
tmcahn
Removing headline?
drill into the middle of theteak bung (plug)> use a drill bit the same size as the bung, and drill until you come to the screw. clean out the hole, then remove the screw. when you replace the headliner you have several choices to finish to off without replacing the bungs. Let me know when you are to that point. tmc
tmcahn is offline
