SailNet Community - View Single Post - Poorly Running 9.9 Merc Outboard
post #12 of Old 04-17-2009
pdqaltair
pdqaltair's Avatar
I ran lab tests on Startron and other regarding separation...
Originally Posted by Lostmt View Post
Here some information on ethanol fuel problems. Sea Foam also contains alcohol.
http://www.starbrite.com/whatsnew/ST...%20p3072D2.pdf
It can be purchased at WalMart in the boating section.
and E-10. ALL SNAKE OIL. No product had any measurable effect. I used standard ASTM tests. If you are interested in running your own tests, I can tell you how. I hate bogus advertising.
Keep the tank full (fill when you return to the dock, not when you head out) and sail lots - those are the cures.
I guess I worded that strongly. As I said, I ran the tests. I was actually hoping some product would work.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
