I like it, this is a real world test.
Just a question though, shouldn't you deduct the jig drag first before makeing assumptions?
25-12=13 and 50-12=38
So either 13/38 almost 1/3 less drag from fixed to free wheeling.
or
38/13 almost 300% increase in drag by not allowing the prop to free wheel.
Thanks for the insight.
Since you are kinna have the jig and all maybe you might try to a torque number with a stalled prop?
Maybe a one foot bar attached to the end of the shaft to your scale and the hinge locked.
Originally Posted by Maine Sail
No not necessarily. On this jig it related to 25 pounds and this jig showed roughly a 50% difference. Due to the angle of the rope and some other factors it is tough to calculate an accurate drag number.
I also load tested the jig alone, without a prop, at WOT and it had about 12+/- pounds of drag so you would need to subtract the 12 pounds from the 25 or 50 pound numbers to even get close. I think it is safer to say something like "nearly double" the drag difference rather than apply a number in pounds. I leave the .001's up to MIT...
Pretty close an not bad for a back yard hack who did not go to MIT...
