Bob—
That's an interesting idea... I don't know if it would work. You need to have a weight at the end of the drogue, to sink it down into the water so it can absorb the loads. The problem I see is that the double strip of webbing and the central trip line are going to be even bulkier than the existing design is. Also, the cones would probably be far more complicated to make, since the terminal end isn't connected to a central rope, and without the terminal end connection to the central rope, they'd have to be re-designed and heavier material.
