SailNet Community - View Single Post - Mast base organizer?
post #16 of Old 01-05-2005
DelmarRey
DelmarRey's Avatar
JCM,
I put mahogany risers under the organizers and clutches. Epoxied and fared in the corners with triangular strips with one side having a radius, sanded to a smooth radius and epoxied it all in, sanded again, filled any nicks with epoxy filler, sanded again and painted.
I raised the halyards up off the deck for two reasons! I don''t like that green stuff growing under the lines when not in use, a big problem here in the Pacific NW. And the organizers would have required some special geometry with the angle of the deck, the angle of the organizers combined with the exit height of the halfmoon blocks. Plus there''s less of an opportunity for the halyards to wear the deck paint.
The vessel is an old (79) Choate 40 IOR racer. The gelcoat has seen better days so paint is it''s outer coat now, making it easy to make modifications without worry.
Now, I just need to close in the cockpit and raise the winches. Then she''ll look like a Swan 40. Same hull design.
DelmarRey is offline
