SailNet Community - View Single Post - Silicone
Thread: Silicone
post #17 of Old 04-22-2009
sailingdog
And if you take the time to do it right immediately, you won't spend all the time trying to fix it later, or fix the damage from the leaks the half-assed approach will leave you to deal with.
Originally Posted by sailingfool View Post
If your issue is that the lens in a hatch is leaking, then you should just remove and rebed the lens...using only silicone, unless the OEM has a different specific recommendation. It's a simple job, the work is mostly removing the old sealant from the lens and the alu frame. Get those clean, and resetting the lens is a piece of cake, and it will last for many years. Smearing a coat on top may not be successful, and is not likely to look too good.
sailingdog is offline
