SailNet Community - View Single Post - Silicone
Thread: Silicone
post #19 of Old 04-22-2009
Bene505
Glad I found Sailnet
Bene505's Avatar
Originally Posted by sailingfool View Post
If your issue is that the lens in a hatch is leaking, then you should just remove and rebed the lens...using only silicone, unless the OEM has a different specific recommendation. It's a simple job, the work is mostly removing the old sealant from the lens and the alu frame. Get those clean, and resetting the lens is a piece of cake, and it will last for many years. Smearing a coat on top may not be successful, and is not likely to look too good.
Yes the lens is leaking. I ought to try taking it apart and rebedding it. Not sure there's a downside since I'll have to get it professionally done anyway, if I do nothing or if I screw it up.
Either way, I REALLY want to stop the leaks.
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
