SailNet Community - View Single Post - Cutting and drilling Acrylic 1/4" sheet for windows.
post #6 of Old 04-22-2009
jarcher
jarcher's Avatar
Originally Posted by Northeaster View Post
Have you considered using something like 3M VHB tape, as an adhesive, instaed of drilling / using screws / bolts that will leak later. Also use something like Dow Corning 795 or 791 adhesive sealant to keep the water out.
Dow 795 and Dow 791 are both silicon based sealents, so if you are planning to seal the acrylic against the fiberglass you may want to consider a different adhesive. As has been discussed here, silicon is bad for fiberglass.
jarcher is offline
