SailNet Community - View Single Post - Portable Generators
post #2 of Old 04-22-2009
mbradl
Gasoline Generators
Here are some points on my experience with small generators (owned Honda 1000 from 97 -2007 and have been enjoying Honda 2000 since)
- Run them completely out of gas before storing below - decks - you may have to do some plumbing modifications if some gasoline remains in tank that cannot be drained by opening carburetor bleed screw
-I am currently using a coiled-up shore power cord (standard plug) for plug in and because of large gauge wire and 2000 watt generator I seem to be doing okay...had a short combo cord on my last boat for the Honda 1000
-consider the Honda 2000, it isn't much bigger than the 1000 and runs for around 8 hours on economy - it is much more difficult to trip than the old 1000 (when initial battery charging done you can run vacuum etc without disconnecting loads) and one guy was running a 5000 btu ac off his last summer
-I don't know anything about the honeywell but several boaters I know like the Honda - after owning different sets from yamaha, coleman etc,
the big thing I keep hearing is noise, we also thought paying a little more for a quality generator might make sense since we would primarily be using it in a marine environment (have heard that some bargain sets go bad after corrosion issues)
Good Luck,
Mark
mbradl is offline
