SailNet Community - View Single Post - How to remove sole panels in N33
post #2 of Old 04-23-2009
KeelHaulin
STARBOARD!!
KeelHaulin's Avatar
No... I don't think they are removable. At least they are not in my N-41. If they were meant to be removed there would not be screws/bung plugs. Pretty sure that the sole is glued to the balsa cored floor pan on your boat; just as it is in mine. The best you can do is -carefully- sand the floor in place without sanding through the teak/holly veneer which is about 1/16" thick. Another option is to just re-cover the exsisting floor with new sheet of teak/holly veneer or plywood. There is a plastic laminate product that looks like teak/holly that can be glued over your existing floor also.
KeelHaulin is offline
