Originally Posted by watom
How do you run your cable from the dock box to your boat? What is the connection you use at the boat it's self, is there a proper waterproof marine connector similar to the shore power cord,or do you just run the coax cable thru a open port light. Moving aboard soon and cable TV and Internet is available at the dock box my old boat wasn't wired for cable.
Thanks.
I would at least investigate grounding the coax once it is on board, possibly running it through a grounding block and then wiring the block to earth ground. I think that is how it is wired when it comes into your house, I seem to remember the cable company even drives it's own ground rod.
