  #16 (permalink)
Old 04-28-2009
sailingdog sailingdog is offline
Running wire that is slightly oversized is actually a good idea, if you can afford to do it. It will help protect the boat in case of a short, since the wire will be less likely to heat up and cause a fire before the fuse blows or circuit breaker trips. It also can give you expansion capability for future use. I generally recommend running wire that is at least one size, if not two, larger than what the circuit or equipment requires.
Originally Posted by Coreyboy18 View Post
So I saw this post, and while I am referencing Don Casey's Sailboat Electrics Simplified, I still have this question: Can I have a wire that is "too big"? And I don't mean a 2 gauge(AWG) wire for a 25 watt light, but if I bought a 12 gauge wire to run my electronics (which include VHF, knot meter, cabin lights, small cabin fan, steaming light, running lights, bilge pump...and I think that is it actually), would that be a big enough gauge. And I also mean that they will be on separate circuits. Thanks in advance!
