SailNet Community - View Single Post - What guage do I use
post #18 of Old 04-28-2009
sailingdog
I wouldn't buy Ancor wire as it is generally way overpriced. I'd go with Berkshire cable, which is available from GenuineDealz.com.
If you're serious about installing AC on the boat, it would make sense to install a shorepower outlet and an AC battery charger, along with some outlets. The small inverters are great for small loads, but if you're at the dock, it would make sense to have a shorepower setup.
Basically, you'd need a shore power inlet plug, a shore power main panel, a GFCI outlet and a good AC powered battery charger.
For a battery charger, I'd recommend you go with an Iota charger, available here.
sailingdog is offline
