SailNet Community - View Single Post - Screws into fiberglass
post #2 of Old 04-29-2009
sailingdog
Use thickened epoxy, not plain epoxy, a plain epoxy is awfully brittle. Drill the holes in the thickened epoxy and drive the screws in without coating them. If you coat them with epoxy, you probably won't ever be able to remove them.
BTW, the best dodger connection system is using a track and bolt rope IMHO. The studs are a PITA and don't hold the dodger in place uniformly.
sailingdog is offline
