SailNet Community - View Single Post - Endeavour 32 1980 - good or bad?
post #7 of Old 04-29-2009
Csobanc
Endeavour 32
I am looking for a boat in the 30' range as a first boat as well... Have a few questions myself if you would not mind answering...
The size and make of the motor is mentioned a few times here... if the boat would need a new or remanufactured engine, gearbox shaft, seals and prop... any ideas what this would cost?
What year is your boat? I am looking at a few listings and the late '70 boats seem to be avail. around $15K-$18K... is yours a '70s boat? Anything you can recommend looking at (by a novice sailor/buyer before a surveyor is brough in)? Also it seems that these boats come with either centerboard or shoal draft... are they both reliable systems? I was told that the centerboards would need inspection more often due to corrosion problems... Someone at another forum also mentioned that they have a hard time backing out of the slip (under power) turning to port... they do not yet know why, they suspect the screw may need to be replaced with a different type. Any thoughts on this?
Thanks for any additional info you can provide.
Csobanc is offline
