SailNet Community - View Single Post - Shaft Log Leak (Pics)
post #18 of Old 04-29-2009
Capnblu
Capnblu's Avatar
Ok, so here is my GUESS. I think that your cutlass bearing housing, is leaking around it's perimeter, where it exits the hull. If it were mine, and after reviewing the other suggestions, and ideas, and it still seemed plausible, I would haul the boat, pull the shaft (into the boat), make an airtight plug and insert it into the stuffing box inside. I would get some butyl tape, and tape an area off completely surrounding the cutlass bearing area 2-3' cover with poly so you have an airtight bag, and insert a vacuum source. check and halt any air leaks. Now look for water being pulled OUT of the hull. My 2 cents thinks its going to be leaking on the outer perimeter of the cutlass bearing. For a good vacuum source, go to your local refrigerator repairman, and ask him for a refrigerator compressor. These will draw a nice vacuum to about -25psi. Do not think you can use your own, by cutting it out of your old fridge, Let a professional empty and dispose of the refrigerant. Good luck.
Why, why, why?
I Don't Know! I Don't Know!
Capnblu is offline
