  #19 (permalink)
Old 04-30-2009
ScuzzMonkey ScuzzMonkey is offline
ScuzzMonkey is on a distinguished road
Originally Posted by hellosailor View Post
Adam, if you have a split backstay, installing the pole becomes a bit harder. But for a single backstay...you can either have the pole sitting in a "cup" (i.e. a piece of PVC pipe a foot tall) and the top end inserted in another piece of pipe with no top on it. Then all you need to do is lift the pole up out of the cup, and pull it back down (out of the top) letting it fall past the transom.
PO did this on my boat even though it has a split backstay. He just angled the cup to match the angle of the stay; it holds up just fine. To deploy, just pull the base out of the cup, and let it drop in the wake. Never had to use it in anger, but I've tested it and it works fine.
