Old 04-30-2009
sailingdog sailingdog is offline
sailingdog is just really nicesailingdog is just really nicesailingdog is just really nicesailingdog is just really nice
Dave—
The problem is that Garmin uses the 12 VDC ground as the signal ground. So, to get it to work with the ST4000, you need to connect the Garmin (Blue or Grey) NMEA out wire to the ST4000's RED NMEA+ in wire, and then you have to connect the ST4000's BLUE NMEA- wire to the Garmin's 12 VDC ground.
Be aware you probably need to set the Garmin's serial port to the NMEA 0183 protocol, as they are set to Garmin's proprietary protocol by default IIRC. Set the ports to NMEA 0183, 4800, 8, N, 1.
Originally Posted by db27513 View Post
Im trying to connect my 545s to my ST4000. Has anyone done this? The Garmin says to use two wires to connect to a NMEA device: a Blue NMEA out wire (positive), and a ground. The ST4000 labels its NMEA inputs as Data in +ve (a red wire) & Data in -ve (a blue wire).
The problem? Garmin calls its blue wire as positive (RXD+) while Autohelm says the blue wire should be negative. Autohelm also doesnt mention anything about grounding the other lead..
Any clues?
Thanks
Dave in NC
If you're new to the Sailnet Forums... please read this POST.
Sponsored Ad
