SailNet Community - View Single Post - Is this a real Hinckley?
post #9 of Old 05-01-2009
Maine Sail
Maine Sail's Avatar
The OC's
While the Hank Hinckley Ocean Cruising Yachts are very fine boats, built to a much higher standard than most, they are not a "Hinckley".
I spent a great deal of time at Hinckley when they were still pumping out a fair number of sailboats as a friend worked there. The robust quality of construction and level of attention to detail in a Hinckley is, in my estimation, rarely equaled anywhere on the planet, except for down the street at Morris. Morris builds a beautiful boat too and there are a few European builders doing a similar level but the OC's are just not to that level IMHO but still EXCELLENT. I've been on many Hinckley's and two OC's so I have had a chance to compare both. The SW 42 sails like a dream, though it can be a tad wet, the OC 42 while nice does not have the sailing qualities of the SW 42. If you've ever seen how Hinckley's are built, up close and personal, compared to other builders, you'd understand.
Don't get me wrong the OC's are top notch just not "THE" top notch IMHO.
P.S. How many builders do you know that let a master varnisher spend 320 man hours just on a master state room...?? I'll give you a hint it was not OCY..
______
-Maine Sail / CS-36T
Maine Sail is offline
