Thread: Grounding
Old 05-02-2009
Coreyboy18 Coreyboy18 is offline
Coreyboy18 is on a distinguished road
Originally Posted by RanAweigh View Post
Hi Corey,
Bring all of the DC returns (ground) to a common point a ground bus.
Here are some samples to help you identify what you are looking for:
A Barrier Strip can also be used as a bus by linking the terminals together
The bus is ultimately connected to the NEG terminal on your battery
Hope it helps
Great, thanks a lot. It does actually help quite a bit. I think in the process of reading all of this electrical info, I starting mixing AC and DC when it comes to grounding. So now it is a matter of getting the strip. Thanks a lot for your help, you too SD.
Corey
Lake Pontchartrain and beyond (hopefully)
1978 Ranger 23
