My son's Bayfield 36 has a split mainsheet. I was on the boat for several days and I liked it, it was easy to adjust and it also acts as kind of a preventer. I don't know that you get as much precise control as with a single sheet and traveller, but unless you are racing I think it works very well.
That does make sense. Easier is good. I guess the important thing would be the ability to quickly release the mainsheet. And the preventer would be good for keeping the sail steady downwind while crossing wakes.
I think you can get just as good control with a split mainsheet setup as a traveler... but much less conveniently. It's usually easier to adjust a good traveler setup than to "tweak" the sheet, esp at the higher wind ranges, so having to adjust two mainsheets (often far apart) won't be as smooth or as accessible.
Also, more line on the cockpit floor..... On the plus side, less cost, the cockpit is clear of traveler obstruction and at anchor you can secure the boom very well with the two sheets pulling against the topping lift/halyard - much less tendency for the boom to swing in some waves and a more secure grab point too.
btw - re the Vang... a missing vang is not deal breaker, but should be way up on your list of things to do as soon as possible....
On the plus side, less cost, the cockpit is clear of traveler obstruction and at anchor you can secure the boom very well with the two sheets pulling against the topping lift/halyard . . .
Another one on the plus side is that the absence of a traveller (depending on its location of course) will not result in anybody's fingers lying twitching on the deck.
With travelers you can have settings and pre-assigned "gears", numbered even.
Can't see how you can do that with split mainsheets.
I'm rather a novice. By split mainsheet do you mean a line from
the boom to Port through a block, and a line to starboard through
a block where you pull on one and release the other to control
the angle of the boom?
Yep, it's a 3:1 or higher purchase system run through blocks on the cabin roof, situated on either side of the companionway entrance. There's no mainsheet traveller. Pull one end, the boom goes that way, pull the other end, the boom goes this way, let both out on a broad reach or run. I've never used it, but that's my understanding.
Related Threads
1.7M posts
173.8K members
Since 1990
