SailNet Community - View Single Post - Trailer vs Haul/store/launch
post #10 of Old 05-06-2009
christyleigh
christyleigh's Avatar
I did the marina slip, self haul, launch, and store in my back yard with a couple trailer sailors with a Chevy 1500 pickup for a few years. Neither required a tongue extension or relying on the tides....... BUT.... Every ramp is different. The ramp in E. Greenwich RI on NGBay was steep enough so floating off was always ... interesting.... but quite doable.
One boat was a water balasted 26' with a swing keel for a year and the other was a 25' Nimble Arctic Pilothouse Sloop with a 4' * Edit * Draft (may have been only 3' 6" Draft not Keel) fixed keel for 2 years. The Nimble also had an excellent Mast Tabernacle system for reasonably easy raising and the other much lighter built 26' had an A-Frame setup to also fairly easily raise the mast. Back in the 80's Catalina had the 25 with a 1000lb swing keel that was a reasonable sailor and now I beleive the newer fixed keel version is also trailerable.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
christyleigh is offline
