Just to play Devil's Advocate... I'd point out that non-use is worse for a boat than constant use with good maintenance. I would be worried about the "pristine" appearance of the Hunter, especially if it is the result of the boat having been cleaned up just for sale. Often, a boat that isn't used will also be neglected and not have the basic maintenance done to it.
I'd also recommend you read the
Boat Inspection Trip Tips thread I started, as it will help you determine what shape both boats are really in...
However, it does sound like the Hunter would be the better choice of the two. PO's can do a lot of strange things and fixing what they do can be very frustrating.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
