A 170 genoa is intended for light winds only, and will be severely stretched out if its wind range is exceeded, hurting performance as you believe.
A 153% genoa will incur no rating penalty... maxing out at 135 will give you a rating credit.. either move will likely result in improved results on the score sheet - and likely on the water as well.
1984 Fast/Nicholson 345
