Old 05-09-2009
DropTop's Avatar
DropTop DropTop is offline
DropTop is on a distinguished road
Based on your previous thread, I had thought you were still deciding between boats.
I was at the time, I had been trying to decide for a while, and I was down to crunch time to make a decision. The Catalina was deliverd to it's summer storage location today, and if I hadn't decided what I wanted to do in regards to her in advance I would have had to pay for the slip too, which would be fine if it wasn't 2 hours away... The comments and feedback I received was enough to convince me that my gut feeling was correct, and go with the Hunter. However just to make keep a calm head, I low-balled the offer $5k under his already $3k reduced price to see how the owner took it (he's despirate to unload), and he took it. 53% of his original asking price, Decision made!
I hope you're getting your own survey done, by a surveyor of your own choosing...
absolutly. I only meant that I took peoples advice and did my own first before spending money on one, and I am pretty confident that this survey will say the same as the recent one. Doesn't mean I'm going to skip it by any means.
I would recommend using the old jib for a while to see if you really need the roller furling...
You're not the first person to suggest that, and I found out today that there is already a downhaul for the Jib (since the mast isn't stepped / rigged I didn't see that for myself when inspecting her), so I might give it a shot for the season, but I still want one if for no other reason then saving deck clutter while out if the jib is not being used for short periods of time.
Get a good polyethylene holding tank. For heads, get either the Raritan PHII or the Lavac.
I'll definitly look at those, thanks for the suggestion!
[QUOTE=sailingdog;484187]
I would recommend that you plumb the head as follows, as it maximizes the flexibility of the system and minimizes the amount of plumbing and possible problems...[QUOTE]
I'll check into that, flushing with fresh water is nice sometimes, however I have just filled a jug and dumped it in the bowl in the past. I'll check to see how hard that will be to setup...
Go with LED navigation lights while you're at it...
Excellent Idea!
Do you mean dodger and bimini?
nope, meant awning. don't think there would be any headroom with a bimini
installed that fits under the mast
**EDIT** meant to say installed under the boom, it was late, and I was tired. didn't proof read.
as far as the rest, I apprecieate your suggestions, I'll definitly make a note of them for when I'm planning everything out over the next few months!
