SailNet Community - View Single Post - Replacment Pushpit
post #2 of Old 02-01-2005
WHOOSH
Replacment Pushpit
Tree, I would defnitely recommend a metal fabricator that works - at least in part - in the marine trades. Aside from searching forever, the key benefit would be that designing your own replacement pulpit allows you to take a lot of other things into consideration than simply the attachment points on deck. Halyard snapshackle connection points, a mounting point for a ''real'' bow light, ergonomically accommodating the anchor roller, add''l bracing that will make it stronger, and perhaps even considering a pulpit extension that reaches all the way back to the first deck stanchion on each side - all these are things I would consider if redesigning my own pulpit.
Jack
WHOOSH is offline
