SailNet Community - View Single Post - Watermaker brine discharge question
post #10 of Old 05-12-2009 Thread Starter
Zanshin
Zanshin's Avatar
I neglected to post the solution to the black-discharge question. I had traced the lines incorrectly, the black discharge came from the water exhaust on the generator. It would only be black when run at load, which is why I only saw (see) the issue when making water. The unit should produce 17Amps at 230V for continuous duty, but at 11Amps it seems to be overloaded - which is another topic that I'm trying to solve (a new injector might do the trick)
Zanshin is offline
