SailNet Community - View Single Post - Where to get a good deal on a new outboard
post #4 of Old 05-14-2009
sailingdog
The motor mount probably says that because for the maximum HP it is rated for, the four-stroke motor will be considerably heavier than the two-stroke version, and it will break under the weight and force of the four-stroke motor. Unless you're close to the maximum weight and HP for the bracket, using a smaller four-stroke on it should not be an issue. For instance, if you have a bracket that is rated for up to a 10 HP two-stroke motor or 100 lbs., putting a 9.9 HP four-stroke motor on it, that weighs over 100 lbs. is probably a bad idea. But I would be seriously surprised if that same bracket couldn't handle a 8 HP four-stroke motor that is 85 lbs.
Johnson apparently still makes a two-stroke motor. The four-stroke motors are far more fuel efficient and usually quieter than the two-stroke variants, but a bit heavier.
sailingdog is offline
