SailNet Community - View Single Post - Seacock Leaking
Thread: Seacock Leaking
post #2 of Old 05-15-2009
sailingdog
I am willing to bet that the block of wood that was used as a backing block is rotting and the rotting wood has allowed the thru-hull to break its seal against the hull and that is the source of the weeping.
Yes, you'll have to haul the boat to replace the seacock and through-hull.
Yes, you'll probably be able to wait until Tuesday.
Not a whole lot that you can do to stem the water flowing in that won't cause a huge problem later, when you're trying to replace the through-hull and seacock.
sailingdog is offline
