SailNet Community - View Single Post - Seacock Leaking
Thread: Seacock Leaking
post #9 of Old 05-16-2009
DrB
I don't like to use wood backing plates for below waterline
seacocks because of this very reason: Wood will eventually rot if kept wet and unprotected. A rotting base plate in a critical application can lead to a leak.
I would use a 3/8 to 1/2" thick fiberglass/epoxy plate instead. They are easy to make even with a curved contour and will be impervious to water, expand an contract similarly as the hull and strong enough to be through drilled and bolted.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
