SailNet Community - View Single Post - Crack in bilge on E-29
post #8 of Old 05-18-2009
Sailormann
Here .. Pull this
If there was water in there and the boat had frozen it could have done that damage as the surveyor suggested. It might just be wear and tear too. The crack looks like it runs fore and aft. If one side of the keel structure has a heavier layup than the other side, and/or if the boat has/had gotten waterlogged, the lateral force exerted on the keel when the boat heels could just have been enough to open it up on the one side. There may also have been some stress applied to the hull if it was blocked poorly on the hard.
If it was my boat, and I had not paid a lot for it, I would probably dry out the bilge and epoxy several layers of cloth and resin in there on both sides of the keel with two or three more layers on the cracked side. It would be a good idea, as SD suggested, to grind out the brittle resin that is there now and put a strong fillet there. The boat could be good for another twenty years...
But I'd make a point of NOT sailing the boat too far offshore
Sailormann is offline
