I think you should check your source again... not the case with the SPOT messenger... there are some dead spots, but it does have far greater coverage than merely 200 miles off shore.. What you may be thinking of is the XM satellite weather service, which is limited to about that distance.
Originally Posted by theartfuldodger
Spot is only good for 200 miles off shore
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
