I just installed a slide out stove shelf with stowage that utilizes the dead space that was behind the old stove. I still need to finish the wood work for the stowage below the stove. It is designed so that the old Kenon stove and original wood work can be replaced should it ever be desired. I chose the Force 10 2 burner stove with broiler, less expensive than the version with the oven, also consumed less space. Still can do toast in a couple heart beats. I'l post the pic with it slid out with the stowage full of food and cook set. Check out the write up :
Stove
