SailNet Community - View Single Post - WESTSAIL 32 and similar
post #15 of Old 02-11-2005
Billpjr
I fully agree with the WestSail owner about some of the cut and paste assessments. I guess I have to get the mallet out.
Failure to mention lead for ballast. Biased info based on lack of knowledge? Or just biased info? There''s a huge diffence in motion, moment and stability between iron/concrete and lead. Lead is usually better.
Motion/roll studies? The Navy''s were probably done on ships and not 32'' boats. It''s humorous to even compare studies of one to the other. I worked on ships and sailed 1000s of miles in 30''ish size sailboats. Short motion on a ship means you can walk the deck without grabbing the rails. Long motion means you can''t walk without grabbing a rail. Short motion on a 32'' sailboat means you can''t be comfortable because it whips you too fast. Bunk boards and pillows needed to keep the body from moving so you can sleep. Wide easy motion means you rest without them...Westsails yes, modern go fasts no. There''s more but you should get my drift.
If anyone is of the go fast mentality then a WS isn''t the boat for them. It''s a 32'' boat with 18k lb displacement. If you want to race a 32'' boat get 6k displacement fin keel rig. If you want 18k lbs in a fast boat buy a 40''r.
I could go on with more examples but won''t...just don''t rely to heavily on what any single person posts on boats no matter how well read they seem to be.
Also keep in mind that WestSails have proven themselves capable and seaworthy by many circumnavigations for about three decades. You will be hard pressed to find WS owners unhappy with their boats.
Good luck.
Bill
Billpjr is offline
